impose a reflection map on a material/object
Hi all
I am looking for a way to impose a spherical reflection map (only reflection) on an object. Only that object. Actually, even sub-object restrained by a mask. I want the spherical map (an HDRI) to only contribute to reflection, I don't want it to light the scene.
A bit link a chrome material, except the entire reflection would be artificially imposed by me via and image.
In scanline, I would just plug a bitmap in the reflection slot, set it's coordinates to 'spherical environment', and that's it.
lee_griggs
The skydome light has light contribution attributes so that you can disable everything except specular reflections. However, this would be for all objects in the scene.
https://docs.arnoldrenderer.com/display/A5AF3DSUG/Lights#Lights-Contribution
You could also try using the ray_switch shader for this:
https://docs.arnoldrenderer.com/display/A5Af3dsUG/Ray+Switch+shader
Lee Griggs
Arnold rendering specialist
AUTODESK
