Denoiser / Depth artifacts on large scene scale
aronPN6LG
Message 1 of 1
aronPN6LG
I found something weird and thought I'd post it here. So if anybody else find has something similar he or she knows whats up.
I was doing some testing with the denoiser Noice and found some weird diagonal lines in the denoised result. After some looking around I found the depth pass, which is used by the denoiser, to be the culprit.
It turns out if you're working on a big scale (client file) the depth pass can have a weird result.
This gets used in the denoiser and results in a weird effect.
So the fix is simple. Scale the scene down and it's all fixed
depth pass graded to see the effect
noisy render
denoised render with the artifact
Replies (0)
