Cryptomatte AOVs not working in Arnold 6 with both GPU and CPU rendering?
mpowers
Message 1 of 9
mpowers
It seems Cryptomatte AOVs are not working in Arnold 6 with both GPU and CPU rendering (MaxtoA 4.0.2.24). I see it is listed as not working with GPU renders, but there is no mention of it not working in CPU renders.
Is there a date when this feature will be re-enabled? This is a big part of our workflow.
Thnx
Mike Powers
Director of Animation \ Cramer
[email protected]
https://vimeo.com/mpowers
3DBOXX W8920Processor 32.0 GB RAM
Dual Xeon CPU E5-2670 0 @ 2.60GHz, 2601 Mhz, 8 Core(s), 16 Logical Processor(s)
Windows 10 Enterprise - 1809
NVIADIA Dual RTX2080TI 11GB V 419.35
Replies (8)
Message 2 of 9
Stephen.Blair
Cryptomatte works with Arnold 6, I just tested it the other day. If there's a problem, it's either the scene set up or the specific plugin you're using.
Update: I just tried with 3ds Max 2020 and the latest MAXtoA, and cryptomatte worked.
// Stephen Blair
// Arnold Renderer Support
Message 3 of 9
It works on my end with cpu. Latest updates and max version.
Probably the same issue as the other topic. Add the cryptomatte to the maps for aov shaders.
Message 4 of 9
mpowers
I am using max 2020.0, because of backburner issues we were having with 2020.3. Which max are you using?
This my setup max:
And in AfterFX:
Mike Powers
[email protected]
Message 5 of 9
I indeed use max version 2020.3
Did you add the cryptomatte shader as I did? That's not visible from your screenshots.
Message 6 of 9
mpowers
I bet that is it. where did it go before MaxtoA 4.x.x
THANK YOU!
Mike Powers
[email protected]
Message 7 of 9
It used to be underneath the aov section, you can see it in the documentation:
https://docs.arnoldrenderer.com/display/A5AF3DSUG/Cryptomatte
Now it has the same location, but the aov manager has a popup window.(the window in your screenshot)
So go to the render settings and the aov tab and there add the cryptomatte map to it like on my screenshot.
Message 8 of 9
mpowers
Thnx Michiel and Stephen. That was straight up user error 😞
However, once I moved from 2020.0 to 2020.3 and the most recent MAXtoA, only the CPU renders build the correct cryptomatte EXRs.
Mike Powers
[email protected]
Message 9 of 9
Yes I have the same experience, gpu doesn't work.
