Backplate.
Backplate.
raymondwganderson
Backplate.
raymondwganderson
Hello folks, is there any way in Arnold Render to apply a different Backplate image from the HDRI that lights the model?  ie Scene / Model lit with a specific HDRI but using a backplate from a different HDRI. [ see attached model ] I want that lighting but a different backplate [ I have 1 in mind ]
wernienst
Yes, that's possible. Open Render Setup, Arnold Renderer tab, go down to Background (Backplate), change Source to Custom Map.
raymondwganderson
@wernienst  Many thanks for the info. Still having problems though. I have used a jpg as a backplate as I dont have it in png. [ not sure if that makes any difference though ] as you will see The floor of the hdri is still visible and the backplate seems too small and very faint  [washed out].  I used a bitmap node from the material editor and used it for the backplate. I am quite obviously going wrong somewhere. see attached.
wernienst
For both Environment and Backplate map you should choose Spherical Environment as Mapping.
The file type doesn't matter (I think). You may add a Color Correct node to adjust brightness/contrast. However, if the Environment map is also used for illumination, it should be a real 32-bit HDR map. And you should add an Arnold Skydome Light and assign it to its Texture channel.
raymondwganderson
@wernienst , Apologies for the late reply , Thanks to your help I have now managed to sort out the backplate. Another aspect learned. Attached is the look that I want [ although I would like my render to be a wee bit sharper,  that will be for another topic though ] this is done using the default Arnold render settings.  Many thanks.
