Dynamic Block with Array of rivet holes problem.
xanderwirsch
xanderwirsch
Good day all,
I have a dynamic block that I use to stretch to the right size for fabrication of panels.  I am trying to get the block to automatically add holes as the panel is stretched.  The holes need to be spaced equally at maximum 16" o.c.  I have set up all my formulas, etcv and in Block editor it looks good.  The array is showing properly, etc.
The problem is that when I stretch the panel, the holes and formulas do not automatically update.  In fact when I stretch the panel, the Constraint dimension that I use for my calculations doe snot stretch with the panel.  It moves.  Therfore my formuals are not updating and the array is not working as required.
I have tried numerous attempts to get this to stretch with the panel to no avail.  Maybe there is another way to do this.  Ideally when i stretch the panel, the holes should update as per my formulas.
Any help is appreciated.
I have attached the block for reference.
Libbya
Try making it a 'path' array using a construction line as the path.  Stretch the construction line.
xanderwirsch
Hi.  Thanks for the advise.  I have done all types of arrays to do the holes.  The problem is that I need the dclinear constraint to do the calculations.  If the d1 dimensions does not change, the formulas do not updated and recalculate.  I can get the holes at exactly 16" o.c. but I need them equally spaced.
j.palmeL29YX
Attached an example (only the lower array) how you may achieve your needs.
If you need to calculate the values for the array, you must use parametric constraints. Do not mix with dynamic parameters and actions.
(I ignored the slots because I don't know where you want to have place these).
Let us know if you need more detailed assistance.
Jürgen Palme
xanderwirsch
Wow!  Thank you so much.  I am going to review and study this.  I was definitely underthinking this process.  I need to add these rivet holes to all sides but hopefully I can learn from this.  Thank you so much.
rosie_lucas1
Hello @xanderwirsch,
Just checking in—did the responses shared by @Libbya and @j.palmeL29YX help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Rosie | Community Manager
j.palmeL29YX
@xanderwirsch wrote:
I am going to ... study this.
... hopefully I can learn from this.
For a better understanding here two videos to show detailed the steps.
Hope that helps.
(view in My Videos)
(view in My Videos)
Jürgen Palme
