Hello
Currently Window display- X ray controls and visual cross sections do not work on reference data . It works only on surface data .
step 1
I load engineering data through reference manager and want to do measurements with the existing surface data by creating visual cross sections through cross section editor.
step 2
I changed the visibility setting to 1.0 in Window display- X ray controls
step 3
I turned off the Window display-Toggles-Model so that i can clearly see the visual cross sections.But the visual cross sections on the reference data disappears.
It will be good if we can see visual cross sections using X ray setting even on the reference data with out promoting the geometry.
