Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Subdivision Surfaces planarize vertices
I was working with the new SubDiv-Surfacing in Alias 2020 (inkl. Update 2020.1) recently.
An awesome new feature, I like it 🙂
I was wondering, is it possible to get a kinda "Planarize Hull"-Function for SubDiv's
At the moment I use workarounds like this:
- building a Construction-Plane and snap the vertcies to that; or
- building a curve through the vertices. Planarize that curve. And than align the vertices to that curve
Would be helpful if there is a tool to do that automatically.
Cheers,
David
2 Comments
brian.osborn
Hi David, maybe this is obvious ( sorry if I've misunderstood) but if you use the Subdiv/Align to curve set to linear, then it will have the same effect as your work-around without having to planarize the curve?
However this only works with a line of vertices, not a series in different directions, for this the only way I can see is as you describe , using a construction plane - so I agree would be nice to be able to do this in a faster way - bit like the scaling functionality along an axis in speedform.
Brian
Hallo Brian,
Thanks for the comment.
Exacly what you said 🙂
Subdiv/Align to curve with linear option aligns the points on a perfectly straight line.
with quadratic option is a little bit closer, but still because its just a degree 2 curve it changes the curvature a lot.
In a rather big Subdiv-model with a few s-shapes in the geometry, Subdiv/Align to curve will not give good results.
Your mentioned scaling functionality in speedform is what i ment. I actually use a similar way in Maya ... picking many vertices and scale to 0 on one axis. So that is a third workaround 🙂
Planarize hull for Nurbs-surfaces does it that way: keeps more or less the curvature of a surface while "projecting/snapping" the cv's to a plane (view based, or approximated).
in Alias Subdiv a exact "planarize hull" function will not really work, because of complex Subdiv hull's. But it may work with picking a bunch of cv's (with a lasso or box maybe) to than planarize in view-direction or an approximated plane.
Cheers,
David
