Converting format Problem (WIRE to DXF)
My name is Won Yong and I have attached my DXF data converted from ALIAS file as adviced by Mr. Kawada, Autodesk Technical Support team.
I have some problem with converting the file and my collegue cannot open my DXF data converted in ALIAS DESIGN.
(If I convert it in RHINO, it work)
As my DXF cannot be attached, I attached also dwg file.
Thank you
Best regards,
Won Yong CHOI
1 Comment
joe.doyle.yyz
What problem are you seeing? I imported it into 2018 successfully; however, the result was very small. I had to zoom into the origin to see the profile. Please provide more details if you are seeing something different.
Joe
