Check Model Tool
Check Model Tool
 Can the continuity failure surfaces be sorted or colored in a way so that it helps to work and rectify them.
Thank You
2 Comments
Hello Sadatsan ,
After doing the model check ,
1) You can sort it out by clicking the tab which shows G0 ,G1,G2 failure
2) Shift select the the surfaces on the left for selecting the surfaces
3) Then you can assign a different color
I hope this helps
Thanks Sid. This was an Suggestion for Autodesk to implement in future versions if possible. I meant why cant the Model Check Tool do this on ist own? Like we can sort out sections in mesh command instantly Best Regards Sadat
