Vertices and edges are not visible for SubD cylinder.
Message 1 of 12
When a create a SubD cylinder, Vertices and edges are not visible or not being created along with it. This makes me unable to manipulate the shape. Is there a setting where you can toggle on/off the vertices and edges or is this some other error, Please help.
Replies (11)
Message 2 of 12
KaiTi.L
Hi @Anonymous,
to see the vertices and edges you need to select the subdiv object and turn on the CV/Hull in the Control Panel.
Make sure your object is not toggled.
To toggle your model or turn the cv/hull on you can also use the marking menu through cntrl+shift+rmb.
I created a custom Subdiv shelf/preset you can try.
You can import it through the Menu> Preferences> User Preferences Set option box> Make sure the options are check-marked.
Turn CV on/off is mapped to a hotkey L / O
Message 3 of 12
KaiTi.L
Sorry I made mistake with the first attachment.
Please use the second one.
Message 4 of 12
Hello, Thanks a lot for the help including the custom shelf.
Message 5 of 12
KaiTi.L
Message 6 of 12
If this issue is with Dynamo for Revit, please post your issue on the Dynamo for Revit Issues page.
If this issue is not a bug report or improvement request, please check the Dynamo forum, and start a thread there to discuss your issue.
Message 7 of 12
Pleased to see your issue as I think I have the same problem , I am also confused and in need of light on this same issue. Need help.
Message 8 of 12
Awesome and interesting article. Great things you’ve always shared with us. Thanks. Just continue composing this kind of post.
Message 9 of 12
I highly appreciate your hard-working skills as the post you published has some great information which is quite beneficial for me.
Message 10 of 12
replyUTGYT
Community Visitor
Community Visitor
thank you for sharing information...
JCPenneyKiosk
Message 11 of 12
reply3DQ6U
Community Visitor
Community Visitor
Thank you for sharing..
AFC Urgent Care
Message 12 of 12
scottERWE4
Community Visitor
Community Visitor
I recommend you wonderful site reports that will help you write any written work
American Eagle Credit Card Payment
