Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Vertices and edges are not visible for SubD cylinder.
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
4226 Aufrufe, 12 Antworten
When a create a SubD cylinder, Vertices and edges are not visible or not being created along with it. This makes me unable to manipulate the shape. Is there a setting where you can toggle on/off the vertices and edges or is this some other error, Please help.
12 ANTWORTEN 12
Nachricht 2 von 13
KaiTi.L
als Antwort auf: Anonymous
Hi @Anonymous,
to see the vertices and edges you need to select the subdiv object and turn on the CV/Hull in the Control Panel.
Make sure your object is not toggled.
To toggle your model or turn the cv/hull on you can also use the marking menu through cntrl+shift+rmb.
I created a custom Subdiv shelf/preset you can try.
You can import it through the Menu> Preferences> User Preferences Set option box> Make sure the options are check-marked.
Turn CV on/off is mapped to a hotkey L / O
Nachricht 3 von 13
KaiTi.L
als Antwort auf: KaiTi.L
Sorry I made mistake with the first attachment.
Please use the second one.
Nachricht 4 von 13
Hello, Thanks a lot for the help including the custom shelf.
Nachricht 5 von 13
KaiTi.L
Nachricht 6 von 13
If this issue is with Dynamo for Revit, please post your issue on the Dynamo for Revit Issues page.
If this issue is not a bug report or improvement request, please check the Dynamo forum, and start a thread there to discuss your issue.
Nachricht 7 von 13
Pleased to see your issue as I think I have the same problem , I am also confused and in need of light on this same issue. Need help.
Nachricht 8 von 13
Awesome and interesting article. Great things you’ve always shared with us. Thanks. Just continue composing this kind of post.
Nachricht 9 von 13
I highly appreciate your hard-working skills as the post you published has some great information which is quite beneficial for me.
Nachricht 10 von 13
replyUTGYT
thank you for sharing information...
JCPenneyKiosk
Nachricht 11 von 13
reply3DQ6U
Thank you for sharing..
AFC Urgent Care
Nachricht 12 von 13
scottERWE4
I recommend you wonderful site reports that will help you write any written work
American Eagle Credit Card Payment
Nachricht 13 von 13
davidMD5QK
Thank you for sharing this information..
Summit County Auditor
