Surface Fillet Continuity Update Problem
Look into the 2018.0 file i attached. It is not posible to me to force the surface fillet tool achieve at least positional continuity.
I can change all the settings and the surfaces are updatet accordingly. But the position is not achieved. Therefore other fillets, crossing this surfaces, will fail. Undoing the fillet and building it new gives no problems.
For some reasons it refuses to adjust the grading of the fillet surface.
Sure in this case it would be no problem to build the surface new. But actually it is embedded in a model with a lot of other geometry crossing this surfaces and all are combined using the fillet tool. So deleting this fillet results in lots of work.
AliasJB
Hi digiformer,
I downloaded your file, but there was no history, so I rebuilt the surface.  Did you try turning on Bezier?  That seemed to work for me.
Bezier filletBezier fillet
No History? Uh i must have ignored the copy & paste history bug in the 2018.0...
Heres another file with history...
for 2018 i am testing design, theres no bezier option.
But i imported the wire into my old Surface and turning Bezier on also does not lead to a proper calculation.
It seems as if something has seriously knotted in the calculation of this fillet.
weird...
