Surface export to FBX problem
I'm a newbie here. I'm following the steps to export a C3D surface to fbx. First, I export it to solid and give it a thickness. All's well until I export bigger terrain surfaces. It took hours on end to do. What we discovered was it seems to convert each Polygon into an object instead of the entire surface's polygon into one object. So my solution was to abandon the step to convert to solid first and just extrude the triangles from the surface and export the triangles to fbx. This is quicker but still not much improve. It still convert each polygon or 3D face into an object. And with huge surfaces, there're hundreds of thousands of triangles if not millions. Is there a solution to this? We need it in fbx to import into Modo. Thanks.
カワダチアキ
Autodesk Support
Autodesk Support
Hi @Anonymous,
Welcome to Alias forum!
Could you tell me which C3D format you mentioned? AutoCAD Civil 3D format? or Motion Capture data?
And which Alias version you import the data to and try to export as FBX?
Hi Chiakikawada, not quite sure about the format or Alias you asked. I would say it's AutoCAD Civil 3D format. I'm using C3D 2016. The surface was created in C3D.
カワダチアキ
Autodesk Support
Autodesk Support
Hi @Anonymous
I understand you are using AutoCAD Civil 3D.
You posted your question to Autodesk Alias products forum and Alias users cannot provide response about Civil 3D questions.
Could you post this question to below, please?
AutoCAD Civil 3D Forum - Autodesk Community
Oops! So sorry about that.
Victor
カワダチアキ
Autodesk Support
Autodesk Support
No problem 🙂
