Surface export to FBX problem
12:27 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm a newbie here. I'm following the steps to export a C3D surface to fbx. First, I export it to solid and give it a thickness. All's well until I export bigger terrain surfaces. It took hours on end to do. What we discovered was it seems to convert each Polygon into an object instead of the entire surface's polygon into one object. So my solution was to abandon the step to convert to solid first and just extrude the triangles from the surface and export the triangles to fbx. This is quicker but still not much improve. It still convert each polygon or 3D face into an object. And with huge surfaces, there're hundreds of thousands of triangles if not millions. Is there a solution to this? We need it in fbx to import into Modo. Thanks.
