Selecting multiple folders in object lister
Hello ,
When i try to pick objects from multiple folders in object lister at a time ,it only select the objects from the last folder .
The objects in other folder remains unselected.
I select multiple folders by holding Ctrl key and select pick objects with Right mouse button .
Could you tell us on how do we pick objects from multiple folders at a time?
pascal.fessl
with folders you mean layers?
if you just activate layers by holding ctrl key, then release ctrl key and right click >Pick Objects on any of the highlighted layer should select all objects within these layers.
Hello Pascal,
Thank you for your quick reply
Kindly have a look at the attached image.
I have multiple layers in different folders. When i try to select three folders by holding Ctrl key , and by Right click i select pick objects option . It select only the layers in the last selected folder .
bob55
This works for me.  What version of Alias ate you running?
Hello Bob 55,
I am using Alias surface 2017 version. I will have a check in 2019 version and come back.
Hello Bob 55,
It works fine in 2019 version. Thanks for the info.
