mesh shading - simple help needed
Hello all,
what do i have to do to the mesh (left) to make Alias shade the edges and surfaces of the mesh as straight as the nurbs cube?
Thank you for helping,
kind regards...
AaronSevern
In the control panel, under Quality, turn on "Flat Shade Meshes".
Aaron Severn
Principal Engineer
Hi Aaron, thank you for the quick reply. This helps a little.
But unfortunately the flat shade function fails when turning on reflections.
And i cant make it work for the hardware shade mode. Any hints?
I actually did search the help docs for this issue but didnt find anything.
kind regards...
AaronSevern
You're right, the Flat Shade Meshes option only applies to the diagnostic shaders, not hardware shade. Unfortunately, I do not know of a way to do this using hardware shade.
Aaron Severn
Principal Engineer
Thank you for making that clear...
Regards
