Hello!
Last five years our team was working in Alias Surface 2014/2015 on HP Z210 with Quadro 4000. One week ago we've got new machines HP Z440 with Quadro P2000, but still the same Alias Surface 2015. And there is one annoying issue we can’t solve:
All lines without “Wireframe Anti-Alias” option look ragged
This bug appears only if “Hardware Anti-Alias” option is ON
I see Quadro P2000 is certified only for Alias 2018-2019, And there is no information about earlier versions like 2015.
(https://knowledge.autodesk.com/certified-graphics-hardware)
Maybe has anyone encountered this problem?
Thank you!
Solved by Michael-GG. Go to Solution.
Two questions:
First, on your image, the switch in front of "WindowsDisplay > Anti-Alias > Wireframe Anti-Alias" is not activated (only Shaded Anti-Alias is activated). Does activating the switch for Wireframe AntiA-lias change anything?
Second question: does changing the value under "Menu > ObjectDisplay > Draw Precision" do anything?
GG
Hello!
(On old machine I used to work without “wireframe Anti-alias” and i’ve just tried to mirgate preference settings to the new machine with Quadro P2000).
Another moment: If “Hardware Anti-alias” is turned OFF, problem is solved.
2. On screenshots below I’ve showed relation between “Draw Precision” parameter and displaying of wireframe. The worst result is with “draw precision” = 1. More or less acceptable result is with “draw precision” = 0, but small details still get lost.
Thank you!
Draw Precision = 0
Draw Precision =1
Okay, so that means that you can currently work without major issues, right? For your information, we have made some changes to Anti-Alias in Alias 2019.0 and 2019.1, allowing a higher AA value to be used (in case 8x is not sufficient).
If you are fine, can you please mark my answer as accepted solution?
GG
Hello!
Thank you for your answer!
Working with AA 8x is a temporary solution! We’ve got more powerfull machines, but all perfomance is wasted for displaying model in 8x Hardware AA.
I just want to find out where the problem is. Either it is a conflict between new gereneration of videocard and obsolete version of Alias or, maybe, problem could be solved by installing correct driver’s version (I tried to install the latest version and recommended one by Autodesk)
Of course, we can close the problem but it means IT department will think everything is perfect and will buy next 15 machines with the same issues.
On the image below I showed “system info” of my machine. Maybe it will help to find where the problem is.
If you set the environment variable ALIAS_ENABLE_16XAA to 1, you can have higher Anti-Aliasing. But for Alias versions older than Alias 2019 it will also blur the user interface.
If you can get your IT to update your Alias version to 2019 or newer, then you should not have the issue, and be able to use AA 16X. 32X and 64X Anti-Aliasing is only offered in theory by the card, in reality it does not seeem to have any effect than making Alias slower (tested on Alias 2019).
Hope this helps?
Cheers,
GG
Hello!
Unfortunately this is not going to help. Our goal is to work with these settings:
This settings we used on our previous workstations with Quadro 4000.
Right now it is impossible to use this settings because of few things:
We’ve bought new PCs because we wanted to work faster with heavy models. Switching to wireframe anti-alias – ON and hardware anti-alias above x4 reduces viewport performance so we would like to avoid it. Unfortunately buying new Alias 2019 on top of new PCs is not an options at the moment.
So we would like to understand why we are facing all this problems with this particular settings. Is it because of Alias 2015 not being compatible with nVidia Qudro P2000, driver’s issue or something else?
I will try to get this setup checked, and come back to you.
Hi, we have reproduced this issue. It seems that all the P series (P2000,P4000,P5000) of Qaudro graphic cards have the same issue. It will occur when the model is toggled on shaded anti-alias with 4x sampling. We hope this will be addressed om an upcoming release. Thanks!
Hello everybody!
Thank you for your support!
It seems we are talking about two different issues: main issue and little problem.
I’ll try to divide them:
The main problem is dotted lines. You can see printscreen in my first post.
This issue occurs when Hardware AA is ON (4x or 8x — doesn’t matter), and wireframe AA is OFF
In alias 2015 we’ve solved this issue by turning ON Wireframe AA.
Little problem
But when wireframe AA is ON you get flickering lines in viewports when press ALT+Shift. And by switching hardware AA from 4x to 8x we just get rid of this issue.
I presume you are talking about the problem of flickering lines, but not about dotted wireframe. I want to say: this is a problem not of Quadro P-series only. The problem exists also on old Quadro 4000
We’ve started to test Alias2019 on new machines with P5000. And there is an issue with dotted lines even with wireframe AA is turned ON 4x or 8X.
You can see it on screes below: problem exists either when wireframe AA is OFF or is ON (8x)
As I wrote in the very first post, the dotted lines is our main problem.
Best regards
Can you please let us know if you are testing with Alias 2019? We do have known Anti-Alias issues for some cards there, which look similar to the image you posted. These should be fixed with 2019.1. Can you please try that one (if you didn't already)?
GG
Hello!
Sorry for delay reply!
Yes, two last images we’ve got by testing Alias2019.0. And now we are waiting for 2019.1 , but when it will happens, I have no idea.
As mentioned above, the chances are pretty good. We had several customers reporting Anti-Alias issue on 2019, specifically on the P5000, which were fixed in 2019.1 (ALS-4099, ALS-4266, ALS-4332).
Cheers,
GG
2019.1 is already released?
