Keypoint Circle No Attributes Change, 2026
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In Alias 2026, there appears to be no way to edit the radius of a keypoint circle via the information window after you make it. With the rectangle tool you can edit length and width. With a circle there is no attribute box. I swear it was there in previous versions. Can anybody else confirm this? I know a good way also is to instead use a normal circle, let it be made at 100 mm and scale the DIA to what I want using Absolute command entry. But I like the Keypoint method better for accurate sized circles.
SOLUTION! : Must pick the curve not the object. When doing multiple segments, you have to change attributes for each curve. Attributes do not appear with pick>object.
