Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
How do you blend these surfaces?
3 REPLIES 3
593 Views, 3 Replies
Hi everybody
I want to build a blend surface between these ones, but when I pick the lower edge of the second surface, I cannot select it.
The second surface is a draft from a pair of curves attached at position.
How can I solve this kind of issue?
Thanks beforehand
3 REPLIES 3
duaxiong
You can't do that in one surface...or at least you shouldn't; it needs to be two.
in reply to: duaxiong
Thank you for your answer.
TheHangman
Hey aureobird
As mentioned its impossible to have a Class-A in there since you have a kink G0 and bellow the G0 1 Span.
Doing it simpler and dirt I would say use Freeform Blend > turn off the Chain Surface > Set the Flow control to Default so that it blend the First Big Slab from Span down then from G0 Kink to top as another surface, and which would leave a gap in between, and for it you can use a tool that better suits you. SQUARE, BY RAIL, PROFILE BLEND CONTROL and so on. than tweek as you need to acquire a great wash out.
HTH, Happy modelling.
if this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated.
Thanks!!!!
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
