Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Alias launching problem
3 REPLIES 3
636 Views, 3 Replies
I downloaded a demo version of alias design on a PC running vista.
The installation seemed to be successful, but
when I launch alias the first image I see appears as a mirror image. The application also does not finish loading.
I tried installing it several times but I got the same out come each time.
How can I fix that? Is it a graphics card issue?
Help please.
3 REPLIES 3
gusi_cl
Hi all,
I've the same problem. I've installed on my pc Inventor 2011 and Alias design 2011. At the biginning all works well, but today, whitout any reason, Alias design don't start. At the launch, splash screen appears, but don't go away. I've to terminate it using task manager. I've reinstalled but nothing change.
Please help us!!
Thanks!!
claudio
zhuly
I am having a similar problem on Autostudio 2016. It crashes down after finishing start screen.
TheHangman
in reply to: zhuly
Hey folks
Check these threads out you may find a solution.
http://forums.autodesk.com/t5/alias-general-discussion/autostudio-2016-crash-on-start/td-p/5597843
http://forums.autodesk.com/t5/alias-general-discussion/alias-2015-crashes-freezes-on-start-startup-s...
HTH, enjoy.
if this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated.
Thanks!!!!
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
