Hi there...
has anyone found a workaround for my NOT working dolly to MOUSE ???
alls fine till i click on a model ( which happens sometimes ) and a blue little leftover from the hidden POI stays right where i clicked.
after that the cam will only zoom to that point...
help is really appreciated ...
cheers
flo
Hi there...
cheers
flo
have you installed the Service Pack?
Maybe than it is fixed.
Could it be that this issue has something to do with the graphics driver?
Cheers
Rüdiger
Cheers
Rüdiger
Hi...
tx for the answer...
yes...installed it yesterday as i read that they solved some camera issues, but NOT that one 😉 we tried also with several drivers for the quadro and tried also new fire pro with several drivers...no success...
now im really switching between the working 2011 and 2012 as my project involves a lot of trimming...;)
Hi...
do you have subscription at autodesk?
Than we could do some research on this?
anyway can you post a picture of your issue so that I can see more what you mean with " and a blue little leftover from the hidden POI stays right where i clicked"
kind regard
Rüdiger
kind regard
Rüdiger
Hi ...
ive sent already a bug report to autodesk...cant send any pictures from here...
actually, it turned yellow by now which i think is due to normal direction of the surface...
my settings are...dolly to mouse / use point of interest / POI visibility OFF...
in camera view, it keep on zooming to the POI and not to the mouse cursor...
basically same settings as in 2011 except not working same way ...
greets
flo
Hi ...
greets
flo
can you tell me the case number?
than I will have a look in it again.
thanks
Rüdiger
thanks
Rüdiger
Hi...
case number is:
389011 dolly to mouse
cheers
flo
Hi...
case number is:
cheers
flo
sorry there are missing 2 digits.
cheers,
Rüdiger
cheers,
Rüdiger
Thank you for sending your bug report or feature enhancement request.
Your report has been entered in our database as:
We regret we cannot respond directly to all bug reports and feature
enhancement requests we receive, but all reports are carefully logged
and tracked. If you ever require more information on this bug report
or feature request, please refer to it using the number indicated
above.
thats all i got...
flo
above.
thats all i got...
flo
