Converting .WIRE files to STL
chiningglitch
Observer Observer
chiningglitch
Observer
Observer
Hi, I have created heaps of models on Alias, and I uninstalled Alias because it was using to much storage, is there any way of converting my .WIRE files to .STL, please reply ASAP,
wayne.olive
If you have Alias, then the Rapid Prototype tool should be able to do what you need:
File->Export->Rapid Prototype
http://help.autodesk.com/view/ALIAS/2019/ENU/?guid=GUID-1AC6B3C9-31A7-4C50-B381-89AE5AA20B31
cheers,
Wayne
chiningglitch
Observer
Observer
I don't have alias anymore and I don't want to get it.
joelparfait_signi
Community Visitor
Community Visitor
i have alias but i can't visualize this file stl o i don't know the locations of the file
another question, my model was pierced can it run too ?
Fausto_Brevi
You say "I have alias but i can't visualize this file stl". Which STL file? Maybe you forgot to upload it?
kenorjoel
Community Visitor
Community Visitor
I basically made one line of the grid with top and sides, copied and just moved down to make each line of the grid. Made the grid a hole. I centered it on the solid mat. The grid and mat are the same height so when you join them they make the lines. I made the lines 1mm wide x 1mm tall. Red mat is 1mm tall as well https://9apps.ooo/ .
revalakol
Community Visitor
Community Visitor
I was really looking for a compact, quick and clean way to dispense solder, but the existing models don't satisfy me. This looks perfect! As soon as I finish my current print this will be the next one. I've already bookmarked it on printables.
