Alias Forum
Welcome to Autodesk’s Alias Forums. Share your knowledge, ask questions, and explore popular Alias topics.
Converting .WIRE files to STL
5 ANTWORTEN 5
Nachricht 1 von 6
chiningglitch
1679 Aufrufe, 5 Antworten
Hi, I have created heaps of models on Alias, and I uninstalled Alias because it was using to much storage, is there any way of converting my .WIRE files to .STL, please reply ASAP,
Tags (3)
5 ANTWORTEN 5
Nachricht 2 von 6
wayne.olive
als Antwort auf: chiningglitch
If you have Alias, then the Rapid Prototype tool should be able to do what you need:
File->Export->Rapid Prototype
http://help.autodesk.com/view/ALIAS/2019/ENU/?guid=GUID-1AC6B3C9-31A7-4C50-B381-89AE5AA20B31
cheers,
Wayne
Nachricht 3 von 6
chiningglitch
als Antwort auf: wayne.olive
I don't have alias anymore and I don't want to get it.
Nachricht 4 von 6
joelparfait_signi
i have alias but i can't visualize this file stl o i don't know the locations of the file
another question, my model was pierced can it run too ?
Nachricht 5 von 6
Fausto_Brevi
als Antwort auf: joelparfait_signi
You say "I have alias but i can't visualize this file stl". Which STL file? Maybe you forgot to upload it?
Nachricht 6 von 6
kenorjoel
I basically made one line of the grid with top and sides, copied and just moved down to make each line of the grid. Made the grid a hole. I centered it on the solid mat. The grid and mat are the same height so when you join them they make the lines. I made the lines 1mm wide x 1mm tall. Red mat is 1mm tall as well https://9apps.ooo/ .
