Check Model Tool; Check Spacing
Hallo,
Today a collegue and me had a strange problem.
We both used the "evaluate>check model" tool with exacly same settings in the tool-options, the same construction-options, on the same surfaces... but got a different check-result.
That was totally confusing us.
After some trying we found the difference... not were we expected it.
the check-model-tool resulting locators always refer to the last selected settings for the evaluate>surface-continuity tool.
Means, if you use different surface-continuity-options during a check/correction-loop, the next check may show different results.
The important difference in our case was the "Check-Spacing" option of the surface-continuity-tool: he used option "Arc-Length"/1mm; and I used "# Per Span". His check showed "clean", mine showed many errors.
And also here an other confusing thing. The actual spacing for "Arc-Length" is defined in the surface-continuity-tool; the option "per span" refers to the number of "Curve-Fit-Checkpoints" in the construction-options.
So:
Wouldnt it be less confusing to separate this tools? maybe just also show the locator-settings in the check-model-tool?
or even one step further... In our company all the modelers are using the very same construction-options for final checking.
For me it would make sense to put the "Check-Spacing" into the global construction-options, so the checking-options can be exchanged/preset easily. And than maybe the surface-continuity-tool gets a "override"-button to change the parameters, so that specific locators can be placed with other settings.
Greetings, David
mitchellt89
 Hi David,
Thank you for reporting this. I was not able to find a case in my test files where changing the options you mentioned in the Surface Continuity Options changed the Check Model result. However, I was able to confirm your finding that Check Model does use those options in some way, so I would like to clarify: in your case, did changing the options in Surface Continuity give you the same Check Model results as your colleague?
I agree that options in one tool should not affect another tool. We will look into a solution, which will likely involve either moving these to Construction Options or adding them to the option menu for all affected tools, as you suggested.
Mitchell
Hallo Mitchell,
Thanks for the reply.
When I used the same setting for surface-continuity-tool as my colleage, the check-model-tool was also showing the same result.
So the check-model worked the same on both pc's.
But while the Construction-Optios and Check-Model options were exacly the same all the time, we first couldn't find our mistake.
We just didnt thought of changing the surface-continuity-tool affect the check-model result.
In our case it may be a unlucky accident. Because we had some tiny fillets in a panel-gap, so some patch-boundaries were shorter than the accidently used Arc-Length Check-Spacing of 1mm.
The Arc-Length-Spacing we usually don't use. Thats also why we dont thougt of this.
I uploaded an example-file with a similar situation.
I also left some locators there, so you can watch the locator settings with the info-window.
Both sides of the panel-gap are same dirty, but if you use locators with arc-length, it shows ok, with #per span it shows mistakes.
regards, David
