Autodesk Alias Surface wont display save as dialog
Message 1 of 8
Autodesk will not open the save as dialog, or any other windows dialog.
I have read about the filedia variable, but I cant seem to find the option in Alias.
Can someone point me to where its hidden? or a solution?
Help would be greatly appreciated!
Replies (7)
Message 2 of 8
bob55
I don't believe the filedia variable effects file dialogs in Alias.  You can certainly try to set the registry entry.
https://knowledge.autodesk.com/support/autocad-lt/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Au...
When you select Save As does nothing happen or does Aias Hang.
Message 3 of 8
Nothing happens, alias continues to work just as before.
We have used checkpoints, wich save without opening a Dialog to at least continue to work.
It sems to be stuck to a specific user, and not bound to the Workstation she uses.
I will try the registry.
Thanks for the reply.
Message 4 of 8
bob55
Assuming she is on Windows she should remove this file
%%APPDATA%\Autodesk\Alias\UserPrefs[VERSION]\.AliasBrowserPrefs
Message 5 of 8
Sadly did not resolve the Problem.
We are most likely going to wipe the computer right now.
Message 6 of 8
bob55
Did you try removing the preferences first?
Message 7 of 8
We deleted the user Profile, we reinstalled Alias, hence deleting the preferences as well. A different Pc will work, but the problem traveled with the user if she logs on.
I am kind of out of ideas here.
Message 8 of 8
Im having the same behavior in Alias Surface and Autostudio; (my employer has both). I’m here because I’ve managed my own machines before with Alias & Windows. The on-site IT support staff would not know what to ask in this case.
