Alias Design Marking Menu Slow
Message 1 of 51
Alias Design marking menu is running very slow.  Experience lag of about 0.5 to 1 second between marking menu swipes/flicks. It doesn't sound like much but it feels like an eternity- I've always worked fast in Alias, never had this issue before in past 7 years.
Replies (50)
Message 2 of 51
bob55
Have you just upgraded?  How about Surface or AutoStudio?  Is it only when you have a large dataset?
Message 3 of 51
It's a fresh install on a new computer. Using Alias Design specifically. The files are not large, maybe 40MB at the moment.  (i've worked with 1GB+ files in past with minimal slowdown so I don't think its the case here)
specs:
Intel Core i7-7500U CPU @2.7GHz  2.9GHz
16GB RAM
WIndows 10 64-bit
800GB free space on the HDD
Message 4 of 51
bob55
What king of graphics and have you updated to the latest driver?
Message 5 of 51
ah, there was an update needed - updated now -- however after restart it's still sluggish.
Nvidia gforce 940MX
driver: 21.21.13. 7719
Also I went into Nvidia control panel to make sure it's set to use the dedicated graphics card and not the intel one.
Message 6 of 51
bob55
What version of Design is it?  How is the response when you use menus, shelves or palette items? For example for the Marking menu shelf itself?  Also what kind of license are you running?
Message 7 of 51
bob55
Your issue may be ralated to this thread ...
Re: Alias Design Marking Menu Slow
Message 8 of 51
Florian.Coenen
Hello @Anonymous
can you also try to reset the software. Maybe some old preferences are causing the issue.
Here is an article about the rest of Alias:
https://knowledge.autodesk.com/support/alias-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
I hope that is helpful.
Florian Coenen
Message 9 of 51
Mark.Palmer
Observer
Observer
I'm having the same issue. Marking menu selections and view manipulation is super laggy. I've been using alias for 11 years and have never had this issue. Brand new workstation and install. The problem is causing the system to be about 2 clicks behind me, causing incorrect selections, moves, etc. super frustrating!
Could this be a network/license ping issue?
Message 10 of 51
bob55
If you are experiencing slow view manipulation, it's unlikely to be related to licensing.  What version os Alias, OS, and Graphics are you running?  I assume you've updated the graphics driver.  Also what is your "Draw Presision" set to (in your control panel under Quality).
Message 11 of 51
Mark.Palmer
Observer
Observer
I'm running Windows 7 Enterprise
Alias Surface 2018 build 60
Driver: 22.21.13.8205 on Quadro M6000
Thanks for your support!
Message 12 of 51
bob55
You obviously have a sufficient rig. what is your "Draw Precision" set to (in your control panel under Quality).
Message 13 of 51
Florian.Coenen
Have you guys already done a reset of Alias?
Regards
Florian
Florian Coenen
Message 14 of 51
Mark.Palmer
Observer
Observer
Interestingly I had a crash, and after I relaunched Alias the issue seems to be gone. Any idea what the issue could have been based on that?
Message 15 of 51
bob55
When you say re-launch, do you mean fromthe msaved dialog box?
Message 16 of 51
Mark.Palmer
Observer
Observer
Yes
Message 17 of 51
Mark.Palmer
Observer
Observer
Yes
Message 18 of 51
bob55
A little about your usage... Do you typically exit Alias during the day? How long do you typically run for.
Message 19 of 51
I run Alias Design on a PC. I have the same issue with super slow marking menus but only on my home 4K HP display, no slowdown on my work display (Apple display) which is not a 4K display. Not sure if the 4K is the issue?
Message 20 of 51
bob55
Are The menus actually slow to draw or is the tool slow to start?
