Alias crashes constantly while trying to open one particular saved file
rickyngowda
Message 1 of 10
rickyngowda
Alias is crashing constantly whenever I try to open one particular saved file. The other files open successfully without any problems.
This is the crash report I get -
Error: Access violation - code c0000005 (first/second chance not available)
Crashed Module Name: libGeometryDefn.dll
I am using the 2023 version.
May I know how to solve this issue?
Thanks in advance.
Replies (9)
Message 2 of 10
robin.oldroyd
Hi, sorry to hear you are having issues.
When you go to file open can you pick the option box you will see a lot of options to Keep Windows, cameras, etc. turn all of these off and see if the data loads.
Once loaded you might need to create a new perspective camera to vie the data.
If that works then you can try opening it again with some of the more important elements like Layers. See if it opens and try to recover as much of your file.
Hope that helps.
Robin Oldroyd
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Message 3 of 10
bob55
If what Robin suggested does not work, you can try to loading the file into an older version of Alias, if you have access to one.  If that works there still may be some data loss.
Message 4 of 10
rickyngowda
Thanks for the response. I tried this but it still crashed 😕
Message 5 of 10
rickyngowda
Unfortunately, I do not have access to another version. If you have another version, maybe I can email the file to you?
Message 6 of 10
bob55
Send me a private message (hover over my name) and attach it, or if it's too big, upload it to one drive (or something) and send me the link.
Message 7 of 10
robin.oldroyd
Sorry that did not work.
An alternative to different version is to open it in maya, it sounds like something is getting in a loop that can not be broken. If you don't have maya share the file with me and I will see if I can open it and send it back.
Cheers
Robin Oldroyd
Message 8 of 10
rickyngowda
I have already sent the file to you on private message. Thanks
Message 9 of 10
Michael-GG
Hi all, have you been able to solve this issue?
Michael G.-G.
Manager Quality Assurance Automotive
Message 10 of 10
bob55
Unfortunately The best we could is recover his file in 2017 ( a version before subdivs) so his subdivs were converted to nurbs. It can be read by 2020 (the first release of subdivs), but any file written out cannot be read by a later release.
