Vertical holes in the components (profiles, plates) with non-parallel connected objects
In the case of objects that are not connected in parallel (not parallel position of the connection surfaces = ), non-vertical  holes and double holes (double green circles) are created. This makes identifying the same parts difficult and does not work properly - different positioning of identical components, problems with NC, ...
3 Kommentare
bigcarl5000kg
Here an example from transmission towers sector to describe the problem above:
Gap between the parts 0,8°
Double green circles for holes will be generated:
The command "audit" finds this problematic entity, but cannot delete / resolve it - it cannot be done manually.
After numbering, identical (mirrored) parts will have different SP / MP, due these double holes.
IR8ASU1
@bigcarl5000kg I tried replicating your issue, but found no issues with identical parts or NC as per screenshot below. Have I misunderstood your point here?
bigcarl5000kg
Try to generate a profile drawing with sloping holes and focus on the shape and orientation of the hole ...
Look at the holes in the angle in DXF ... they have shifted and do not climb the same gauge line
Automatic connections ... like Bolt on beam .. can only be used to a limited extent -> if they are actually generated
Connection detail:
Idee einsenden
