Advance Tool Palette - Custom connections - add direct screw definition
For the tools like bolts on beam, bolts on beam gauge line from the Advance Tool Palette / Custom connections, the possibility to define the bolts / anchors / holes directly is missing. Please add the definitions directly to the tools (similar to other tools for the fasteners - Bolts on center point, rectangular, ...) and make the work easier.
1 Kommentar
bigcarl5000kg
Bolt on beam definition - no direct possibility to define the screws:
It must be done in 2. step in another menu / window, after selecting the screw and the right button:
Idee einsenden
