Variable corner cut for shear plates and for stiffeners along x and y
Every state project (95%+)  has stiffener plates  / shear plates with clips per attached screen pic with different values.
I have made once request to the tech support in USA, but the gentleman either passed away or was fired, and so far no results.
The clip values along x and y are different and are function of web thickness of the beam or girder.
Every state has it's own specifications and currently we have to explode each macro in order to modify the value's.
This applies for stiffener and for shear plate macro.
If I have to pay-please send me a quote. I just need it almost on each project.
Ilko Dimitrov
5 Comments
haedicu
haedicu
Status changed to: Archived
Due to a low support of your peers, your great idea is not considered for implementation at this time. Thank you for your contribution, every idea has merit. We always encourage you to rework and resubmit these ideas based on feedback received.
acbsdesign
This is a mandatory on State Projects, If you want Advance to be used more often on such projects-this has to be implemented.
Ilko Dimitrov
Edited by
Discussion_Admin
I think it is a bit short sighted to expect users to stumble on to this post and then like it for you to put a high priority on it. Send an email to all the registered users and ask them. I bet then you would see the huge need for this simple addition. I would contribute to the cost as well, that is how much this would save time and mistakes in the shop. Please be proactive and look into codes and expectations from engineers in the US and not just Europe.
Thanks in advance for adding this to what is already a great product. But if you want to make it better, please listen to us, even if there are just a few of us that care enough to actually say something. And by the way, my list of things I want is long, so once we get this done, I will be glad to share.
Jeff
acbsdesign
@Anonymous,
Well said, ...unfortunately we have to work with what we have...
Ilko Dimitrov
