When you define a threaded hole you must set the hole tolerance to zero or the hole thread does not match the bolt thread. However, Clash Check shows all these holes as clashes. The user has to either ignore each clash individually one by one (very time consuming on some models) or set the bolt ot not include in clash check (dangerous).
Please fix the clash check so it recognises a threaded hole with a hole tolerance of zero as correct not a clash.
