Threaded holes are not a clash
When you define a threaded hole you must set the hole tolerance to zero or the hole thread does not match the bolt thread. However, Clash Check shows all these holes as clashes. The user has to either ignore each clash individually one by one (very time consuming on some models) or set the bolt ot not include in clash check (dangerous).
Please fix the clash check so it recognises a threaded hole with a hole tolerance of zero as correct not a clash.
1 Kommentar
Shawton2000
Right on the mark if I could vote 1000 times I would.  Threaded holes at 0 tolerance shouldn’t cause clashes and Switching off “use for collision checks” is a dangerous thing to do especially with bolts.
Idee einsenden
