THE ABILITY TO SPLIT A RAILING
It is often necessary to split a railing, maybe for transport, or installation or to maximise section lengths. It is possible to create a railing in a number of sections to accomplish the above but consideration must be given to the start and end position of posts to allow continuity of the railing. By far the easiest method would be to create a continuous railing and split the railing after. It would also be good if a gap can be included when splitting to allow for joining spigots etc. Maybe, after splitting, each section of railing could be an independent railing joint so parameters can be changed (height for instance) for each section - in this instance I have a railing on an incline in mind where the height of top handrail may be different to allow for the fall.
1 Kommentar
haedicu
Status geändert in: Future Consideration
Thank you for sharing this idea with us. We will keep it in mind for any future improvement on document management in Advance Steel.
best regards
Udo
Idee einsenden
