it would be nice, when the using of the welding template would be easier / faster.
When I work on a model, according to the country where the manufacturer is located , I need different welding-types (US / EU / AUS)
So in ASteel, in the worst case I have to scroll a lot.
And because Advance doesn't remember the last type of weld I've used, I have to scroll everytime, for every weld, and every counterweld.
But Advance Steel is Member of the AutoCAD-Family, so they should use the menu from AutoCAD Mechanical, which is way easier AND it rembemers the last used weld.
As you can see, there are all needed Informations in one Window, without submenus, and I can select the weld via click, which is easier and faster...
Kind regards
