Select parts for cameras
Hello all together!
I think that the Advance Steel desperately needs an additional option in Camera mode, where the user could select the parts that are going to be visible in the drawing view. I thought about that a lot and in my opinion there should be an option (select/deselect parts) in camera box, so the user could select parts visible in the view and if he would later wanted to add or delete parts from the view he could use the (select/deselect parts) to do so, then the drawing would need to be updated. But that is just my idea. Any other option with similar output would be extremely welcome to all AS Users. I think this would increase GA drawing creation productivity for at least 20%.
4 Comments
ETheuring
Yes, there are absolutely many ways to reach this possibility.
Now these are already 20 years, a long time in which I work with Advance Steel and with every version I hope for this possibility.
Well it would be to combine the existing possibilities in Advance Steel cleverly with each other.
We have groups in the projectexplorer, lot/phase in the properties of the objects and a lot more.
Meanwhile one can generate cameras of model views. Nevertheless, it should be also possible to take over a group in the projectexplorer in a model view. Or the group can be also made the camera.
There is in addition sooo many proposals.
It would be good if the development brings a solution into it, finally, sometimes.
DumitruBerteanu
DumitruBerteanu
Status changed to: Accepted
the possibility to select objects for camera detailing has been added to Advance Steel 2022.
You can find a video here:
Advance Steel 2022: Camera Enhancements - YouTube
Gernot
