Searchable PDF generation
Hello!!
I've been working on one of my projects and found something that would make my work more convenient and other peoples work too, i.e, the pdf files generated from advance steel should be searchable, as whenever we are working with erection drawings we need to give the quantity along with the reference to the Erection sheets and for that either we  have to check in the model or in the erection plan .dwg file or pdf , that too manually, but if the pdf files are searchable then we can search the mainpart mark on erection sheet's pdf and write that in the shop drawing more conviniently.
Looking forward to see this change in the near future.
Thanks.
