Assembly weight needs to be fixed.
Hello!,
I've found an issue that really needs to be fixed in the case of assembly weight, i.e, I created a shop drawing of a single part beam, and noticed that in the BOM on drawing, the assembly weight is higher then the single part weight, and the reason behind that is that, its not considering the copes and notches in case of  assembly weight and showing the overall weight of the beam, while in single part all notches and cuts are considered for weight calculation and so the weight is lower then assembly weight.
It would be great if the assembly weight also considers any modification and cuts on the parts and calculates weight acc. to that.
Thanks.
Hoping for a +ve change in the near future.
Idee einsenden
