Revit Concrete Elements
Autodesk has started or no longer developing Advance concrete, my understanding Autodesk's proposed workflow is to use Revit Structure for highly detailed concrete elements.
If that is going to the be the case, can we have the export & import of Revit concrete elements into Advance Steel completed and comprehensive, no matter the shape or type it is recognised.
At the moment only the common elements are recognised, complex or customised elements are not always recognized.
For example in Revit exported to Advance Steel:
  • Concrete slabs:
    • A standard slab without slope, imports perfectly
    • A standard slab with a slope, using high difference value, the result is variable, especially when slabs join.
    • A standard slab with a slope, using slope value, the result is variable, better handling when slabs joins.
    • A standard slab, using modify sub-elements, not recognised at all.
  • Some cases it has been necessary to show REO in the Advance Steel footings, during hold down detailing.
If we have to use another products to finish the job, it should be expected that all elements, of what ever type or complexity be recognised in the all products.
2 Comments
haedicu
Status changed to: Archived
Thanks for taking the time to submit your idea and to everyone else for contributing your thoughts and votes. Unfortunately, this idea did not get the support of the community and as such we will not be pursuing it. Please feel free to rework and resubmit this one down the road.
I think this idea needs to be reconsidered. Concrete would make this software comparable to Revit and could be marketed as a "design software"
