Joints and structural objects improve use of tables
Using tables is not very comfortable. There is structure missing. What is the use of a template with 100 entries? Basic things to do:
  • if the table of a joint is open, then the entry in the table that is identical to the joint should be shown with bold letters.
  • If an entry is added to the table, AS should check if this entry already exists and either issue a warning or not add the entry
  • There should be an option to find identical entries.
In addition as further imrpovement:
As I already proposed in
https://forums.autodesk.com/t5/advance-steel-ideas/improve-template-structure-using-a-tree-structure...
a tree structure for templates would be great.
And as additional ideas, make filters for
  • preferred templates
  • project specific templates
1 Kommentar
haedicu
Status geändert in: Under Review
Idee einsenden
