Repeat last command
Repeat last command
One of the improvements in AS2017 is that you can right click and Repeat last command for more functions.
Which is good of course.
...but many still do not work and support/dev advised that this was due to "stacked" functions.
However, several years ago, before ribbons & palettes when toolbars were still the norm, ALL commands could be easily repeated.
I attach a few small videos showing how much more efficient it was by comparing toolbars and ribbons.
...so if it were possible to repeat ANY command several years ago, why not now?
Software is all about productivity so to go backwards makes no sense and we should again be able to repeat ANY command without having to click back on its icon.
5 Comments
haedicu
DumitruBerteanu
Hello. With the 2017, the commands can be easly repeated including with the right-click option, where the first option the menu will repeate the last command. This functionallity was removed from the Ribbons, but is now back as a separate enchancement linked to Advance Steel.
Could you please give us an example of commands that are not covered at this point by the repeate last command functionallity ?
beam command (ASTORCRBEAMBYCLASS)  doesnot get repeated in trial versions...
Drawtech
As in the video,
Clear marking + select objects connected in shop
Command: _AstM4CommUnmarkObjects
Command: _AstM4SwitchReprMode MAINSTRUCTURE
Yes it is 2 commands, but when we had toolbars you could right click and repeat.
Basically and stacked functions are no longer repeatable as they once used to be when using toolbars.
...years later and we still cannot do what we used to do - how is that progress?
iwafb
IMO, you should be able to repeat the last command, whatever that is, but simply hitting enter or space. Quicker and easier than right/click select or re-issuing through ribbon/palettes.
I know this can be "customised", but shouldn't it be there? Surely the benefits are easy to see?
