Railing Segments for Fabrication
Add an option within the railing macro to split railing into segments while maintaining macro intelligence.  The split points could be based on the number of railing posts and split a certain distance away from the post (for example you could set it to split into sections with three railings posts max and the split point could be 6" from the third post).  It would be nice to be able to move a split point separately from others if desired (similar to how posts can be moved separately).  Railings are manufactured in sections to allow for ease of fabrication and installation.  The only way to currently split the railing is to destroy the macro.  If there are any changes required after field measuring the railing needs to be re-drawn.
