Grib Rail Elbow Model Role
Add a model role hard coded in the railing macro specific to the elbows in the side mount grab rails.  This would allow easy isolation of all side mount handrails (grab rails).  Currently the macro assigns the bent section between grab rails a model role of "Elbow".  When trying to use Queries to isolate all the grab rails it only shows the straight sections of the rails and not the bent sections.  It would also be nice to be able to change the model role in the "Railing Joint Handrail" joint.  It is possible to change all of these by hand but takes a long time and some are usually missed causing improper dimensions or missing details when creating drawings.
Idee einsenden
