Radial Dimension Improvement
Per attached screen pic, if we need to show radius of contour cut, radial dimension in Advance Steel is not working.
All radii for cuts created with polygon contour are currently made using plain Autocad leader+text.
Ilko Dimitrov
2 Comments
haedicu
Thank you for this idea. We will see how we can improve the radial dimension feature and take it in consideration for one of the future Advance Steel versions.
best regards
Udo
haedicu
Status changed to: Archived
Due to a low support of your peers, your great idea is not considered for implementation at this time. Thank you for your contribution, every idea has merit. We always encourage you to rework and resubmit these ideas based on feedback received.
