plate bending
plate bending
Hello, after giving the command to bend the plates in Advance Steel, it is not possible to perform resizing (enlarging or reducing) the plate. Adding a command to cancel the bending would greatly improve functionality. Currently, when a mistake occurs while drawing a silo funnel, it causes time loss as the bent parts need to be redrawn repeatedly. It would be very beneficial if you could add this feature to the software.
2 Comments
bigcarl5000kg
Hi @a.cinar033,
you don't have to redraw the entire bent sheet, simply right-click on the bend, select delete bend (special function - don't delete it classically), edit the sheets and connect them again to the bent configuration.
Since 03/2023, Advance Steel is in Maintenance mode, no further development from Autodesk.
a.cinar033
Hello, thank you very much for your valuable comment. I didn't know about this feature.
