DWG FORMAT
DWG FORMAT
When obtaining laser cutting files in Autodesk Advance Steel, they are currently provided in DXF format. Would Autodesk consider adding the DWG format in their future updates?
1 Kommentar
bigcarl5000kg
Hi @a.cinar033,
DXF is a open-source format, which are not dependent on SW. Save your DSTV (DXF-Data) easy as DWG.
Since 03/2023, Advance Steel is in Maintenance mode, no further development from Autodesk.
Idee einsenden
