We need options to take scribing into account when producing NC files.
We are looking for 2 new features in regards to NC Files that related to each other.
Currently we are getting enormous pressure from our clients, as this is becoming a more common deliverable.
Our clients tell us their Tekla detailers can do this and we don't want to loose projects over this.
- Firstly we need an Assembly Token to be usable with NC Files, as our clients scribe the part number and assembly number onto the parts. (Reduces marking of the parts once all fittings are assembled)
2.Secondly we need a Ticks Box option in the NC Settings dialog box that opertates such if the scribing of the parts (NC or DXF) differs from one object to the next (that are the same item number) it produces extra NC / DXF Files with a suffix.
For example:
The Assembly here is called B2.
In the above example the 4 vertical subs (part number 1000) are all the same.
But with 3 different scribing scenarios.
The desired result with the above features would produce:
B2-1000-1.nc with a Quantity inside the NC File of 2
B2-1000-2.nc with a Quantity inside the NC File of 1
B2-1000-3.nc with a Quantity inside the NC File of 1
B2-1001-1.nc with a Quantity of 1 (this is the main Part)
B2-500-1.nc with a Quantity of 5 (this is the plate welded onto the vertical stubs)
