Contour Gaps are Inconsistent
This should be unified/fixed between these two connections. The contour gap is not consistent between these two very similar connections which in turn creates columns with 2 different cuts when they should be identical.
This was sent to support as a bug and I was told to post it here.
Image 1
Shear Plate contour gap set at 1/16”. Gap is created around entire plate, top, bottom and both sides
Image 2
Through Plate contour gap set at 1/16”. Gap is created only on the sides
The contour gap should be all around the Through Plate, not just the sides.
1 Kommentar
iwafb
So now we are voting on wether bugs should be fixed??
Idee einsenden
