More fields to fill in informations
It would be great, if there were five or more fields for every object, you can use in every situation. especially in joint makro's. At the moment the manufacturingoptions are very good, but you can't use it at screw's or specialpart's.
For us it would be convenient with the same five or more field's in every object for all situation's.
3 Comments
DumitruBerteanu
Hello Markus, thank you for your input on the Advance Steel IdeaStation !
I would like to ask you some more details about this request : as far as I understand you would need some extra fields for attributes per object, similar to the User Attributes ?
HB-Markus
Hello Dumitru,
I am talking about free useable fields that are useable in all kind of objects. Now the fields in beams are nice, but these fields doesn't excist in every object, so I can't use them well.
These attributes could be a construction phase, so I can sort every object (like: screws, beams, concrete, cladding, ancors, special components, etc.... ) to it's phase.
I know that it is also possible to create groups, but that groups don't work in BOM lists.
haedicu
