Ladder Imporovements
Similar to handrail systems, the current ladder option does not meet ladder trends nor standards in Australia. The standard configuration is ladder with a Type 6 Exit and a Type 3 cage. Currently this is not possible within Advance Steel, you have choice one, explode and manually adjusting the other.
Once you remove/explode the macro, significant type is required and manual labour to make changes. Need to have all ladders, exits & cages working intuitive with one another.
2 Kommentare
DumitruBerteanu
Status geändert in: Under Review
eberg770
This needs to be addressed. If you have anything other than a straight exit (which happens maybe 1% of the time), you would have to manually create/fix the cage after removing the intelligence of the ladder. I need a caged ladder with exit type 6 and cage type 2 that ends at the top of the stringers and now I have to delete the intelligence and manually manipulate the cage to make it work. This will add too much time to my modelling.
Idee einsenden
