Show only
Search instead for
I need a command to create a block of beams. The block shoud work like a connection. And the block can include connections. It shoud have a master slave function. If i copy the block and change the master the slaves will change automatically. numbering with the right quantities for the assembly and SP. create drawings from block. You can read the problem here https://forums.autodesk.com/t5/advance-steel-forum/possibility-to-create-a-block-of-beams/td-p/71051...
